[GRASS-dev] X monitors display rasters half resolution off to the
left
Maciej Sieczka
sieczka at biol.uni.wroc.pl
Mon Mar 5 14:14:51 EST 2007
In Spearfish:
$ g.region rast=landuse -a
$ d.mon x0
$ d.rast landuse
There is a black, vertical artifact line on the right edge of the monitor.
$ d.zoom -> out
It dissapears...
$ d.zoom -> in, until cells are visible
With some luck, you will see such artifact line on the right again -
different colors.
$ d.what.rast
Query some left-most non-null cells. If you click their left side, you
get null instead of the value you expect.
Query the left half of a null cell on the right of some right-most
non-null cell. Instead of null, you get the value you'd expect from
that non-null cell.
Seems like the raster is displayed half resolution off to the left,
compared to d.what.rast query results. A recently introduced bug.
This is propably the reason of the bug I reported as "r.to.vect
feature=lines: the output vector is moved half the resolution east off
the input raster"
http://wald.intevation.org/tracker/index.php?func=detail&aid=322&group_id=21&atid=204
Maciek
