[GRASS-dev] portable.h elimination
Glynn Clements
glynn at gclements.plus.com
Wed Mar 14 08:03:10 EDT 2007
Moritz Lennert wrote:
> > I've modified lib/vector/diglib to determine the byte ordering at run
> > time, rather than generating the portable.h header file.
> > The supplied test case passes. It might be useful to test it using dig
> > files generated on an architecture with the opposite byte order (I
> > have no way to test this). It might also be worth testing it on MinGW.
> How should I test ?
Try using the vector commands on existing vector maps, and creating
some new vector maps.
