Fwd: Re: [GRASS-dev] VTK export for lat-long locations
Benjamin Ducke
benjamin.ducke at ufg.uni-kiel.de
Tue Mar 6 10:45:14 EST 2007
Wow, that explains the result I got!
So I guess you need to know exactly how many meters a lat/long cell
dimension is in the current projection, so you can scale the Z axis
accordingly?
Does this vary between cells? Does GRASS have a function to calculate
metric lengths between two points in a lat-long system? If so, I guess
you would need to take the the metric distance between corner points of
a lat-long cell and use the value for Z axis scaling?
Sören Gebbert wrote:
> -------- Original-Nachricht --------
> Datum: Tue, 06 Mar 2007 16:06:18 +0100
> Von: "Sören Gebbert" <soerengebbert at gmx.de>
> An: Benjamin Ducke <benjamin.ducke at ufg.uni-kiel.de>
> CC:
> Betreff: Re: [GRASS-dev] VTK export for lat-long locations
> Hi Benjamin,
> please dont use the vtk export modules with lat/lon projections.
> The vtk export modules in grass are not
> usable with lat/lon projections right now.
> I think i should put this info to the html docs.
> The lat/lon coordiantes are used to define the coordinates for each point.
> VTK interpret these coordinates as planimetric and not as lat/lon.
> This is not that bad for x,y coordinates, but for the height (z coordinate).
> Because if x and y lat/lon coordiantes are of type [54.001/34.002] and the
> height varies from 0m - 500m you will get a senseless result.
> I still dont know exactly how to implement a meaningful
> lat/lon ->planimetric coordinate transformation to get rid
> fo this behaviour.
> Any suggestions are welcome.
> Best regards
> Soeren
> Datum: Tue, 06 Mar 2007 15:57:17 +0100
> Von: Benjamin Ducke <benjamin.ducke at ufg.uni-kiel.de>
> An: GRASS devel <grass-dev at grass.itc.it>
> CC:
> Betreff: [GRASS-dev] VTK export for lat-long locations
>> Hi everyone,
>> I just tested r.out.vtk in a lat-long location and all I got when I
>> loaded the VTK file in Paraview (2.6.0), was a single line of data
>> projecting through the origin of the coordinate system.
>> Does anyone have any experiences with VTK/Paraview and lat-long data?
>> Thanks,
>> Benjamin
>> Benjamin Ducke, M.A.
>> Archäoinformatik
>> (Archaeoinformation Science)
>> Institut für Ur- und Frühgeschichte
>> (Inst. of Prehistoric and Historic Archaeology)
>> Christian-Albrechts-Universität zu Kiel
>> Johanna-Mestorf-Straße 2-6
>> D 24098 Kiel
>> Germany
>> Tel.: ++49 (0)431 880-3378 / -3379
>> Fax : ++49 (0)431 880-7300
>> www.uni-kiel.de/ufg
>> grass-dev mailing list
>> http://grass.itc.it/mailman/listinfo/grass-dev
Archäoinformatik
D 24098 Kiel
Germany
www.uni-kiel.de/ufg
