Fwd: Re: [GRASS-dev] VTK export for lat-long locations
Markus Neteler
neteler at itc.it
Tue Mar 6 10:43:07 EST 2007
Benjamin Ducke wrote on 03/06/2007 04:45 PM:
> Wow, that explains the result I got!
> So I guess you need to know exactly how many meters a lat/long cell
> dimension is in the current projection, so you can scale the Z axis
> accordingly?
> Does this vary between cells? Does GRASS have a function to calculate
> metric lengths between two points in a lat-long system?
In v.to.db we solved that problem some months ago. The function is
Vect_line_geodesic_length() which is found in lib/vector/Vlib/line.c
markus
> If so, I guess
> you would need to take the the metric distance between corner points of
> a lat-long cell and use the value for Z axis scaling?
> Sören Gebbert wrote:
>> -------- Original-Nachricht --------
>> Datum: Tue, 06 Mar 2007 16:06:18 +0100
>> Von: "Sören Gebbert" <soerengebbert at gmx.de>
>> An: Benjamin Ducke <benjamin.ducke at ufg.uni-kiel.de>
>> CC:
>> Betreff: Re: [GRASS-dev] VTK export for lat-long locations
>> Hi Benjamin,
>> please dont use the vtk export modules with lat/lon projections.
>> The vtk export modules in grass are not
>> usable with lat/lon projections right now.
>> I think i should put this info to the html docs.
>> The lat/lon coordiantes are used to define the coordinates for each point.
>> VTK interpret these coordinates as planimetric and not as lat/lon.
>> This is not that bad for x,y coordinates, but for the height (z coordinate).
>> Because if x and y lat/lon coordiantes are of type [54.001/34.002] and the
>> height varies from 0m - 500m you will get a senseless result.
>> I still dont know exactly how to implement a meaningful
>> lat/lon ->planimetric coordinate transformation to get rid
>> fo this behaviour.
>> Any suggestions are welcome.
>> Best regards
>> Soeren
>> Datum: Tue, 06 Mar 2007 15:57:17 +0100
>> Von: Benjamin Ducke <benjamin.ducke at ufg.uni-kiel.de>
>> An: GRASS devel <grass-dev at grass.itc.it>
>> CC:
>> Betreff: [GRASS-dev] VTK export for lat-long locations
>>> Hi everyone,
>>> I just tested r.out.vtk in a lat-long location and all I got when I
>>> loaded the VTK file in Paraview (2.6.0), was a single line of data
>>> projecting through the origin of the coordinate system.
>>> Does anyone have any experiences with VTK/Paraview and lat-long data?
>>> Thanks,
>>> Benjamin
>>> Benjamin Ducke, M.A.
>>> Archäoinformatik
>>> (Archaeoinformation Science)
>>> Institut für Ur- und Frühgeschichte
>>> (Inst. of Prehistoric and Historic Archaeology)
>>> Christian-Albrechts-Universität zu Kiel
>>> Johanna-Mestorf-Straße 2-6
>>> D 24098 Kiel
>>> Germany
>>> Tel.: ++49 (0)431 880-3378 / -3379
>>> Fax : ++49 (0)431 880-7300
>>> www.uni-kiel.de/ufg
>>> grass-dev mailing list
>>> http://grass.itc.it/mailman/listinfo/grass-dev
