[GRASS-dev] grass location creation
Helena Mitasova hmitaso at unity.ncsu.edu
Wed Mar 7 12:02:06 EST 2007
On Mar 7, 2007, at 2:13 AM, Jachym Cepicky wrote:
> I have the QGIS version here ;-)
> g.region -s would be great...
> however - should it work from PERMANENT mapset only, or from any other
> mapset too?
if you are talking about saving as default region it should work from
as in GRASS  you can change the files only in your current mapset
and the default region is stored in PERMANENT.
This would add an important missing piece - it was a real pain not to
have it
when I started to work with the spearfish replacement data set and I
tried
to work as a normal user (not editing the DEFAULT_WIND files) as my
default
regions we set to 1,1,1 for locations where I used the EPSG code.
thanks for looking into it,
Helena
> jachym
> 2007/3/7, Hamish <hamish_nospam at yahoo.com>:
>> > according to [1] I started to work on GRASS location Wizard.
>> Since the
>> > topic is rather complex, I would like to share some ideas with you,
>> > before I go on it.
>> > I tryed to prepare sort of diagram with the wizard screens and how
>> > they could be organized [3] [4]. General idea is, that we offer
>> to the
>> > user graphical version of standard grass location-creation
>> process. It
>> > should be possible to define default bounding box coordinates
>> based on
>> > list of states or georeferenced file. Thi diagram is not as
>> > transparent as I would like, sorry for this.
>> > If anybody would have some clear picture about how the wizard
>> should
>> > be organized, please share your idea via mailing list or wiki page
>> > [1].
>> > Jachym
>> > [1] http://grass.gdf-hannover.de/wiki/GRASS_Location_Wizard
>> > [2] http://les-ejk.cz/tmp/grassstartup.png
>> > [3] http://les-ejk.cz/tmp/wizard.png
>> > [4] http://les-ejk.cz/tmp/wizard.dia
>> you might look at Radim's GRASS location/mapset creation wizard
>> for QGIS
>> for inspiration,
>>   http://article.gmane.org/gmane.comp.gis.grass.devel/9049
>> The screenshots listed there are no longer available (or at
>> archive.org),
>> but maybe you can find them somewhere else, or just try it in GIS
>> 0.8?
>> I think a big missing piece is (still) a non-interactive "save as
>> default region" option for g.region. Currently there is no tool to do
>> that outside of  lib/init/set_data.c + lib/edit/edit_cellhd.c
>> Hamish
> Jachym Cepicky
> e-mail: jachym.cepicky gmail com
> URL: http://les-ejk.cz
> GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
