[GRASS-dev] Re: [GRASS-user] Compiling grass 6.2.1: i.class error
Glynn Clements
glynn at gclements.plus.com
Wed Mar 14 08:11:30 EDT 2007
Brad Douglas wrote:
> > > Every other --without-* switch should work without requiring
> > > additional effort from the user, but curses is currently sufficiently
> > > ingrained that making --without-curses work nicely is too much effort
> > > for a relatively obscure usage case.
> > ./configure --help
> > --with-glw support GLw functionality (default: no)
> > --with-glw-includes=DIRS
> > GLw include files are in DIRS
> > --with-glw-libs=DIRS GLw library files are in DIRS
> > Is GLw still relevant? If not, let's remove it.
> Can we add --with-motif* to the list?
It's used by xganim, which is still compiled if you use --with-motif.
> And --with-readline* for good measure?
Why? Some people seem to want that functionality in r.mapcalc.
