[GRASS-dev] d.menu, d.ask
Fri Mar 16 14:17:22 EDT 2007
Glynn Clements wrote:
> > You can down load it from the GRASS Addons svn server
> > <https://grasssvn.itc.it/grasssvn/grassaddons/trunk/grassaddons/gui/#_trunk_
> > grassaddons_gui_>
> I already got the code with:
> 	svn co https://grasssvn.itc.it/svn/grassaddons/trunk/grassaddons/gui
> But I just got a bunch of files with no clue what to do with them.
I eventually got around to installing wxPython 2.8.1.1.
gism.py doesn't appear to work; the most noticable thing was:
	GRASS_INFO_ERROR(7945,1): region for current mapset is not set
	GRASS_INFO_ERROR(7945,1): run "g.region"
	GRASS_INFO_END(7945,1)
I'm guessing that's due to line 249 of render.py:
		os.environ["WIND_OVERRIDE"]         = "TRUE"
If WIND_OVERRIDE is set, its value needs to be the name of a saved
region. I'm not sure whether this was meant to be set or not.
