[GRASS-dev] d.menu, d.ask
Michael Barton michael.barton at asu.edu
Fri Mar 16 14:22:35 EDT 2007
This is helpful information. I get this error all the time when running
wxgrass, but it doesn't cause any problems (yet). That is, the gis manager
goes ahead and starts anyway.
Michael
On 3/16/07 11:17 AM, "Glynn Clements" <glynn at gclements.plus.com> wrote:
> Glynn Clements wrote:
>>> You can down load it from the GRASS Addons svn server
>>> <https://grasssvn.itc.it/grasssvn/grassaddons/trunk/grassaddons/gui/#_trunk_
>>> grassaddons_gui_>
>> I already got the code with:
>> svn co https://grasssvn.itc.it/svn/grassaddons/trunk/grassaddons/gui
>> But I just got a bunch of files with no clue what to do with them.
> I eventually got around to installing wxPython 2.8.1.1.
> gism.py doesn't appear to work; the most noticable thing was:
> GRASS_INFO_ERROR(7945,1): region for current mapset is not set
> GRASS_INFO_ERROR(7945,1): run "g.region"
> GRASS_INFO_END(7945,1)
> I'm guessing that's due to line 249 of render.py:
> os.environ["WIND_OVERRIDE"]         = "TRUE"
> If WIND_OVERRIDE is set, its value needs to be the name of a saved
> region. I'm not sure whether this was meant to be set or not.
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
