[GRASS-dev] d.menu, d.ask
Glynn Clements
glynn at gclements.plus.com
Fri Mar 16 15:49:48 EDT 2007
Michael Barton wrote:
> > gism.py doesn't appear to work; the most noticable thing was:
> > GRASS_INFO_ERROR(7945,1): region for current mapset is not set
> > GRASS_INFO_ERROR(7945,1): run "g.region"
> > GRASS_INFO_END(7945,1)
> > I'm guessing that's due to line 249 of render.py:
> > os.environ["WIND_OVERRIDE"] = "TRUE"
> > If WIND_OVERRIDE is set, its value needs to be the name of a saved
> > region. I'm not sure whether this was meant to be set or not.
> This is helpful information. I get this error all the time when running
> wxgrass, but it doesn't cause any problems (yet). That is, the gis manager
> goes ahead and starts anyway.
Another issue: the most recent change to Gism/render.py introduces a
layout error on line 290. Maybe someone has bogus tab settings?
