[GRASS-dev] v.info
Fri Mar 16 16:15:13 EDT 2007
Helena Mitasova wrote:
> I might have missed something, but I am running v.info in about 3 days
> old CVS GRASS
> and it asks for output map? However, the example in the man page is
> v.info map=test
> Why do we need output map for v.info?
> Thanks, Helena
> GRASS 6.3.cvs > v.info -g soils_general
> ERROR: Required parameter <output> not set:
> (Name for output vector map).
> Usage:
> v.info [-hcgt] input=name output=name [--overwrite] [--verbose]
> [--quiet]
If you update the source code from CVS, you have to run "make clean"
before re-compiling; otherwise, you get problems like this.
The specific problem is:
  fieldopt = G_define_standard_option(G_OPT_V_FIELD);
The enum constants in gis.h changed between 1.39 (which is what your
v.info uses) and 1.42 (which is what your libgis uses):
	value revision 1.42   revision 1.39
	 0    G_OPT_WHERE     G_OPT_WHERE
	 1    G_OPT_COLUMN    G_OPT_I_GROUP
	 2    G_OPT_COLUMNS   G_OPT_R_INPUT
	 3    G_OPT_I_GROUP   G_OPT_R_INPUTS
	 4    G_OPT_R_INPUT   G_OPT_R_OUTPUT
	 5    G_OPT_R_INPUTS  G_OPT_R_MAP
	 6    G_OPT_R_OUTPUT  G_OPT_R_MAPS
	 7    G_OPT_R_MAP     G_OPT_R_BASE
	 8    G_OPT_R_MAPS    G_OPT_R_COVER
	 9    G_OPT_R_BASE    G_OPT_R_ELEV
	10    G_OPT_R_COVER   G_OPT_R_ELEVS
	11    G_OPT_R_ELEV    G_OPT_R3_INPUT
	12    G_OPT_R_ELEVS   G_OPT_R3_INPUTS
	13    G_OPT_R3_INPUT  G_OPT_R3_OUTPUT
	14    G_OPT_R3_INPUTS G_OPT_V_INPUT
	15    G_OPT_R3_OUTPUT G_OPT_V_OUTPUT
	16    G_OPT_V_INPUT   G_OPT_V_MAP
	17    G_OPT_V_INPUTS  G_OPT_V_TYPE
=>	18    G_OPT_V_OUTPUT  G_OPT_V_FIELD
	19    G_OPT_V_MAP     G_OPT_V_CAT
	20    G_OPT_V_TYPE    G_OPT_V_CATS
	21    G_OPT_V_FIELD
	22    G_OPT_V_CAT
	23    G_OPT_V_CATS
v.info was compiled when G_OPT_V_FIELD == 18, so that's what gets
passed to libgis, which sees it as G_OPT_V_OUTPUT.
Although we could adopt a policy of not "renumbering" the G_OPT_*
constants, I would rather that people who forget "make clean" get
obvious errors that can be quickly identified than by obscure errors
that cause us to waste hours or even days trying to identify.
I'd even suggest changing G_gisinit() to e.g.:
gisdefs.h:
	#define G_gisinit(pgm) G__gisinit(GRASS_CVS_VERSION, (pgm))
lib/gis/gisinit.c:
	int G__gisinit(const char *version, const char *pgm)
	    if (strcmp(version, GRASS_CVS_VERSION) != 0)
		G_fatal_error("GRASS version mismatch);
The only problem here is that we would have to update the value of
GRASS_CVS_VERSION regularly (e.g. daily) for this to be of much use.
