[GRASS-dev] v.info
Helena Mitasova
hmitaso at unity.ncsu.edu
Fri Mar 16 22:12:56 EDT 2007
That has fixed it, thanks a lot. Helena
On Mar 16, 2007, at 4:15 PM, Glynn Clements wrote:
> Helena Mitasova wrote:
>> I might have missed something, but I am running v.info in about 3
>> days
>> old CVS GRASS
>> and it asks for output map? However, the example in the man page is
>> v.info map=test
>> Why do we need output map for v.info?
>> Thanks, Helena
>> GRASS 6.3.cvs > v.info -g soils_general
>> ERROR: Required parameter <output> not set:
>> (Name for output vector map).
>> Usage:
>> v.info [-hcgt] input=name output=name [--overwrite] [--verbose]
>> [--quiet]
> If you update the source code from CVS, you have to run "make clean"
> before re-compiling; otherwise, you get problems like this.
> The specific problem is:
> fieldopt = G_define_standard_option(G_OPT_V_FIELD);
> The enum constants in gis.h changed between 1.39 (which is what your
> v.info uses) and 1.42 (which is what your libgis uses):
> value revision 1.42 revision 1.39
> 0 G_OPT_WHERE G_OPT_WHERE
> 1 G_OPT_COLUMN G_OPT_I_GROUP
> 2 G_OPT_COLUMNS G_OPT_R_INPUT
> 3 G_OPT_I_GROUP G_OPT_R_INPUTS
> 4 G_OPT_R_INPUT G_OPT_R_OUTPUT
> 5 G_OPT_R_INPUTS G_OPT_R_MAP
> 6 G_OPT_R_OUTPUT G_OPT_R_MAPS
> 7 G_OPT_R_MAP G_OPT_R_BASE
> 8 G_OPT_R_MAPS G_OPT_R_COVER
> 9 G_OPT_R_BASE G_OPT_R_ELEV
> 10 G_OPT_R_COVER G_OPT_R_ELEVS
> 11 G_OPT_R_ELEV G_OPT_R3_INPUT
> 12 G_OPT_R_ELEVS G_OPT_R3_INPUTS
> 13 G_OPT_R3_INPUT G_OPT_R3_OUTPUT
> 14 G_OPT_R3_INPUTS G_OPT_V_INPUT
> 15 G_OPT_R3_OUTPUT G_OPT_V_OUTPUT
> 16 G_OPT_V_INPUT G_OPT_V_MAP
> 17 G_OPT_V_INPUTS G_OPT_V_TYPE
> => 18 G_OPT_V_OUTPUT G_OPT_V_FIELD
> 19 G_OPT_V_MAP G_OPT_V_CAT
> 20 G_OPT_V_TYPE G_OPT_V_CATS
> 21 G_OPT_V_FIELD
> 22 G_OPT_V_CAT
> 23 G_OPT_V_CATS
> v.info was compiled when G_OPT_V_FIELD == 18, so that's what gets
> passed to libgis, which sees it as G_OPT_V_OUTPUT.
> Although we could adopt a policy of not "renumbering" the G_OPT_*
> constants, I would rather that people who forget "make clean" get
> obvious errors that can be quickly identified than by obscure errors
> that cause us to waste hours or even days trying to identify.
> I'd even suggest changing G_gisinit() to e.g.:
> gisdefs.h:
> #define G_gisinit(pgm) G__gisinit(GRASS_CVS_VERSION, (pgm))
> lib/gis/gisinit.c:
> int G__gisinit(const char *version, const char *pgm)
> if (strcmp(version, GRASS_CVS_VERSION) != 0)
> G_fatal_error("GRASS version mismatch);
> The only problem here is that we would have to update the value of
> GRASS_CVS_VERSION regularly (e.g. daily) for this to be of much use.
> Glynn Clements <glynn at gclements.plus.com>
