[GRASS-dev] Re: [GRASS-user] Compiling grass 6.2.1: i.class error
Mon Mar 19 22:30:05 EDT 2007
Hamish wrote:
> > AFAICT, the main problem with v.digit + v.to.rast is that v.digit
> > doesn't have a tool for drawing circles.
> this could be easily remedied, either using a gui circle widget tool or
> just with a line-arrow on the gui canvas to select the center and
> radius, then calculate 360 or so points to define the circle (as r.digit
> does already).
It can easily be done; the question is whether it really belongs in
v.digit. Would you want it for "real" digitising tasks (as opposed to
using v.digit as an r.digit substitute)?
