[GRASS-dev] [grass-web R][340] Grass for Windows installation issue
grass-webr at wald.intevation.org
Thu Mar 22 04:37:57 EDT 2007
web R item #340, was opened at 2007-03-22 12:37
Status: Open
Priority: 3
Submitted By: Javed Shaikh (javeds)
Assigned to: Nobody (None)
Summary: Grass for Windows installation issue
Issue status: needs more info
Site section: Home
Initial Comment:
Hello,
I am new to GRASS system, i have followed all the installation procedure mentioned on http://grass.itc.it/grass62/binary/mswindows/.
After successful installation of GRASS data and Cygwin I tried starting GRASS.
Cygwin window does not recognize command "Startx" it shows the error
As per the instruction if I edit Cygwin_forgrass.bat as
(add "set GRASS_AUTOSTART=1" and "-c startx")
@echo off
C:
chdir C:\cygwin\bin
bash --login -i -c startx
it does not accept the command. If someone can help me in this it would really be appricieated.
regards
Javed S
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=209&aid=340&group_id=21
