[GRASS-dev] v.clean tool=snap snapping any vertices, not only
nodes
Hamish
hamish_nospam at yahoo.com
Sun Mar 25 19:44:14 EDT 2007
Maciej Sieczka wrote:
> I was looking for a tool which would snap nodes of separate lines, to
> connect them into one line. v.clean tool=snap however snaps any
> vertices, not only nodes. Is it a bug? If not, I'd like to fill a wish
> for a new v.clean tool that would snap *only nodes* (of separate
> lines, so that the line would not snap to itself if the threshold was
> bigger than the line's lenght) within the threshold, *leaving other
> vertices alone*.
create a new line to connect the nodes within a treshold? no vertices
are moved, only new connecting lines added. (v.distance??)
or allow movement of the end nodes but not non-node vertices?
Hamish
