[GRASS-dev] discussion: replacing ps.map
Glynn Clements
glynn at gclements.plus.com
Fri Mar 30 18:41:43 EDT 2007
Roger Miller wrote:
> How do you see this contributing to a solution to the complaints that
> have been posted? Is there a plan?
Which complaints, specifically?
My main reason for adding this was to help identify deficiencies in
the graphics API, and in the way that some modules use it. A secondary
reason is that there may be cases where it has practical utility.
