[GRASS-dev] Licence problems in gmath LU decomposition
Sören Gebbert
soerengebbert at gmx.de
Tue May 1 21:26:13 EDT 2007
I have created a new patch for the rst library to test the gpde solvers
with the rst matrices. I have added a new function to rst/interp_float/segmen2d.c (solve_matrix).
If you want to test the different gpde solvers (only cg and bicgstab will work),
just remove or add a comment within the new function.
The created linear eqution system can be printed to stdout,
just remove the comment before N_print_les(les).
This is a quick and dirty hack and only for testing purpose. :)
You have to patch the rst library and v.surf.rst to get it work.
This is the v.surf.rst patch:
Index: Makefile
RCS file: /home/grass/grassrepository/grass6/vector/v.surf.rst/Makefile,v
retrieving revision 1.7
diff -u -r1.7 Makefile
--- Makefile 20 Feb 2004 17:43:33 -0000 1.7
+++ Makefile 2 May 2007 01:16:20 -0000
@@ -5,7 +5,7 @@
EXTRA_CLEAN_DIRS=doxygenhtml
LIBES = $(INTERPDATALIB) $(QTREELIB) $(INTERPFLLIB) $(BITMAPLIB) $(LINKMLIB) \
- $(VECTLIB) $(VECTLIB_REAL) $(DBMILIB) $(SITESLIB) $(GISLIB) $(DATETIMELIB) $(GMATHLIB)
+ $(VECTLIB) $(VECTLIB_REAL) $(DBMILIB) $(SITESLIB) $(GISLIB) $(DATETIMELIB) $(GMATHLIB) $(GPDELIB)
DEPENDENCIES = $(INTERPDATADEP) $(QTREEDEP) $(INTERPFLDEP) $(BITMAPDEP) $(LINKMDEP) \
$(VECTDEP) $(DBMIDEP) $(GISDEP) $(DATETIMEDEP) $(GMATHDEP)
EXTRA_INC = $(VECT_INC)
The rst library patch is attached.
Best regards
Soeren
Index: interp_float/matrix.c
RCS file: /home/grass/grassrepository/grass6/lib/rst/interp_float/matrix.c,v
retrieving revision 2.3
diff -u -r2.3 matrix.c
--- interp_float/matrix.c 29 Mar 2006 20:05:08 -0000 2.3
+++ interp_float/matrix.c 2 May 2007 01:14:15 -0000
@@ -154,12 +154,6 @@
matrix[i][j] = A[m];
- if (G_ludcmp(matrix,n_points+1,indx,&d)<=0) { /* find the inverse of the mat
-rix */
- fprintf(stderr,"G_ludcmp() failed! n=%d\n",n_points);
- return -1;
G_free_vector(A);
Index: interp_float/segmen2d.c
RCS file: /home/grass/grassrepository/grass6/lib/rst/interp_float/segmen2d.c,v
retrieving revision 2.5
diff -u -r2.5 segmen2d.c
--- interp_float/segmen2d.c 9 Feb 2006 03:08:58 -0000 2.5
+++ interp_float/segmen2d.c 2 May 2007 01:14:17 -0000
@@ -8,10 +8,12 @@
#include <math.h>
#include <grass/gis.h>
#include <grass/glocale.h>
+#include <grass/N_pde.h>
#include <grass/interpf.h>
static double smallest_segment( struct multtree *, int);
+void solve_matrix(struct quaddata *data, double *b, double **matrix, int *indx, int ofs);
int IL_interp_segments_2d (
struct interp_params *params,
@@ -249,31 +251,21 @@
}/* segment area test */
- if (!params->cv){
- if (params->matrix_create(params,data->points,data->n_points,
+ if (!params->cv) {
+ if (params->matrix_create(params,data->points,data->n_points,
matrix,indx) < 0) return -1;
- else if (segtest == 1)
- if (params->matrix_create(params,data->points,data->n_points-1,
- matrix,indx) < 0) return -1;
- if (!params->cv) {
- for (i = 0; i < data->n_points; i++)
- b[i+1] = data->points[i].z;
- b[0] = 0.;
- G_lubksb(matrix,data->n_points+1,indx,b);
- params->check_points(params,data,b,ertot,zmin,dnorm,skip_point);
+ /*solve the equation system*/
+ solve_matrix(data, b, matrix, indx, 1);
+ params->check_points(params,data,b,ertot,zmin,dnorm,skip_point);
} else if (segtest == 1)
- for (i = 0; i < data->n_points-1; i++)
- b[0] = 0.;
- G_lubksb(matrix,data->n_points,indx,b);
+ if (params->matrix_create(params,data->points,data->n_points-1,
+ matrix,indx) < 0) return -1;
+ solve_matrix(data, b, matrix, indx, 0);
} /*cv loop */
if(!params->cv)
@@ -340,4 +332,44 @@
+/*Solve linear equation system with different solvers*/
+ int i, j;
+ double d;
+ N_les * les = N_alloc_les(data->n_points + ofs, N_NORMAL_LES);
+ for (i = 0; i < data->n_points - 1 - ofs; i++)
+ b[i+1] = data->points[i].z;
+ b[0] = 0.;
+ /*create the gpde lineare equation system and transfer the data*/
+ for(i = 0; i < data->n_points + ofs; i++) {
+ les->b[i] = b[i];
+ for(j = 0; j < data->n_points + ofs; j++) {
+ les->A[i][j] = matrix[i][j];
+ /*solve it with the bicgstab algorithm*/
+ //N_print_les(les);
+ //N_solver_gauss(les);
+ //N_solver_lu(les);
+ //N_solver_jacobi(les, 100, 1, 0.00001);
+ //N_solver_SOR(les, 100, 1, 0.00001);
+ //N_solver_bicgstab(les, 100000, 0.000000001);
+ N_solver_cg(les, 100000, 0.000000001);
+ /*transfer the result*/
+ b[i] = les->x[i];
+ /*release memory*/
+ N_free_les(les);
+ /* for testing, uncomment this if you want to test the lu decomposition */
+ //G_ludcmp(matrix,data->n_points + ofs,indx,&d);
+ //G_lubksb(matrix,data->n_points + ofs,indx,b);
+return;
