[GRASS-dev] Access of remote Mysql database ?
Stephan Holl
stephan.holl at intevation.de
Wed May 2 05:00:55 EDT 2007
Hello Peter,
"Peter Löwe" <peter.loewe at gmx.de>, [20070502 - 10:40:54]
> Dear all,
> the problem I am dealing seems currently not to be covered in the
> manuals:
> How to hook up a remote mysql-database which requires a login ?
> There is a mysql-database "the_database" with a table "the_table" on
> a remote computer "dbserver.foo.org", which can be accessed by a
> db-user "joshua" (password: swordfish).
> The goal is to establish a layer 2 link between this table (let the
> column be "id") similar to:
> v.db.connect -o map=my_map table=the_table layer=2 key=id
> driver=mysql database="host=dbserver.foo.org,dbname=the_database"
> key=id
what about (untested):
driver=mysql
database="host=dbserver.foo.org,dbname=the_database,user=joshua,password=swordfish"
key=id
> Unfortunately db.login does not provide means to enter a remote
> server.
> Is there a known workaround like hacking the .grasslogin6 -file ?
> Any help would be much appreciated,
Best
Stephan
Stephan Holl <stephan.holl at intevation.de>, http://intevation.de/~stephan
Tel: +49 (0)541-33 50 8 32 | Intevation GmbH | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
