[GRASS-dev] Access of remote Mysql database ?
peter.loewe at gmx.de peter.loewe at gmx.de
Wed May 2 07:22:04 EDT 2007
Dear Markus, Dear Stephan,
thank you for your input.
Here is the correct sequence needed to hook up a remote mysql database, optional commands as comments with a hash
db.connect driver=mysql database="host=dbserver.foo.org,dbname=my_database"
db.login user=joshua pass=swordfish
# db.tables -p
# db.connect -p
v.db.connect -o map=my_map table=my_mysql_table layer=2  key=baz
# v.db.select -c map=my_map_neu layer=1 column=cat
v.db.select -c map=my_map layer=2 column=baz
It would be great if this info would end up in the official documentation.
Peter
Dr. Peter Löwe
Diplom-Geograph
<loewe at geomancers.net>
<peter.loewe at gmx.de>
"Feel free" - 10 GB Mailbox, 100 FreeSMS/Monat ...
Jetzt GMX TopMail testen: http://www.gmx.net/de/go/topmail
