[GRASS-dev] problems with mkftcap
William Kyngesburye
woklist at kyngchaos.com
Wed May 2 11:41:48 EDT 2007
I'm having a different problem with mkftcap - it's getting hung up
doing nothing. One on my processors maxes out and there is no disk
activity for the find operations.
I tried cutting out each part separately - find and fc-list - to see
if one of those was the problem, but no go.
Further cutting points to something wrong in the sed lines - if I
remove those so the raw find and fc-list results are returned, it
finishes.
On May 2, 2007, at 3:00 AM, Glynn Clements wrote:
> Michael Barton wrote:
>>> The command in question is:
>>> find "$dir" -type f -iname '*.ttf' -printf '%f:%p:utf-8:\n'
>>> Does OSX have a command called "find" which isn't the standard Unix
>>> "find" command?
>> find
>> usage: find [-H | -L | -P] [-EXdsx] [-f file] [file ...] [expression]
>> Is this different from the standard?
> No, that's the right command; it appears -printf is a GNU extension.
> That shouldn't be a problem in this case; using:
> find "$dir" -type f -iname '*.ttf' -print | sed 's!^\(.*\)/\(.*\)$!
> \2:\1/\2:utf-8:!'
> should do the same job.
> Glynn Clements <glynn at gclements.plus.com>
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
First Pogril: Why is life like sticking your head in a bucket filled
with hyena offal?
Second Pogril: I don't know. Why IS life like sticking your head in
a bucket filled with hyena offal?
First Pogril: I don't know either. Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
