[GRASS-dev] d.vect.thematic: v.univar.sh -> v.univar?
Daniel Calvelo
dca.gis at gmail.com
Wed May 2 22:52:06 EDT 2007
Markus, could you try the version attached? I think I got it right but
can't access a CVS build right now, so v.univar -e is unavailable for
me right now.
If ok, I'll commit to HEAD.
Daniel.
On 5/2/07, Markus Neteler <neteler at itc.it> wrote:
> It seems to be slightly more complicated (I tried), so I
> leave it for now.
> Markus
> On Tue, May 01, 2007 at 02:49:14PM -0700, Michael Barton wrote:
> > If it does extended stats now and the output is the same, it should be an
> > easy switch.
> > Michael
> > On 5/1/07 8:25 AM, "Markus Neteler" <neteler at itc.it> wrote:
> > > Hi,
> > > can we safely change v.univar.sh -> v.univar in d.vect.thematic?
> > > This might speed up calculations...
> > > Markus
> > __________________________________________
> > Michael Barton, Professor of Anthropology
> > School of Human Evolution & Social Change
> > Center for Social Dynamics & Complexity
> > Arizona State University
> > phone: 480-965-6213
> > fax: 480-965-7671
> > www: http://www.public.asu.edu/~cmbarton
> Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
> FBK-irst - Centro per la Ricerca Scientifica e Tecnologica
> MPBA - Predictive Models for Biol. & Environ. Data Analysis
> Via Sommarive, 18 - 38050 Povo (Trento), Italy
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
-- Daniel Calvelo Aros
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20070502/e0d76822/w.obj
