[GRASS-dev] S-JTSK strikes back
Markus Neteler
neteler at itc.it
Thu May 3 05:50:22 EDT 2007
for a project I need to define a S-JTSK location. I thought
that we resolved this recently, but apparently not:
# S-JTSK (Ferro) / Krovak
<2065> +proj=krovak +lat_0=49.5 +lon_0=42.5 +alpha=30.28813972222222 +k=0.9999 +x_0=0 +y_0=0 +ellps=bessel +pm=ferro +units=m +no_defs <>
So I do:
g.proj epsg=2065
g.proj -w
PROJCS["Krovak",
GEOGCS["bessel",
DATUM["unknown",
SPHEROID["Bessel_1841",6377397.155,299.1528128]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Krovak"],
PARAMETER["latitude_of_center",49.5],
PARAMETER["longitude_of_center",24.83333333333333],
PARAMETER["azimuth",0],
PARAMETER["pseudo_standard_parallel_1",0],
PARAMETER["scale_factor",0.9999],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["Meter",1]]
This is not quite right. It should be
http://lists.maptools.org/pipermail/proj/2003-February/000626.html
something like this:
PROJCS["S-JTSK (Ferro) / Krovak",
GEOGCS["S-JTSK (Ferro)",
DATUM["S_JTSK_Ferro",
SPHEROID["Bessel 1841",6377397.155,299.1528128,
AUTHORITY["EPSG","7004"]],
AUTHORITY["EPSG","6818"]],
PRIMEM["Ferro",-17.66666666666667,
AUTHORITY["EPSG","8909"]],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4818"]],
PARAMETER["longitude_of_center",42.5],
PARAMETER["azimuth",30.28813972222222],
PARAMETER["pseudo_standard_parallel_1",78.5],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","2065"]]
Is any name remapping still missing in
lib/proj/convert.c
Markus
