[GRASS-dev] S-JTSK strikes back
Markus Neteler
neteler at itc.it
Thu May 3 06:09:19 EDT 2007
On Thu, May 03, 2007 at 11:50:22AM +0200, Markus Neteler wrote:
> Hi,
> for a project I need to define a S-JTSK location. I thought
> that we resolved this recently, but apparently not:
> # S-JTSK (Ferro) / Krovak
> <2065> +proj=krovak +lat_0=49.5 +lon_0=42.5 +alpha=30.28813972222222 +k=0.9999 +x_0=0 +y_0=0 +ellps=bessel +pm=ferro +units=m +no_defs <>
> So I do:
> g.proj epsg=2065
> g.proj -w
> PROJCS["Krovak",
> GEOGCS["bessel",
> DATUM["unknown",
> SPHEROID["Bessel_1841",6377397.155,299.1528128]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433]],
> PROJECTION["Krovak"],
> PARAMETER["latitude_of_center",49.5],
> PARAMETER["longitude_of_center",24.83333333333333],
> PARAMETER["azimuth",0],
> PARAMETER["pseudo_standard_parallel_1",0],
> PARAMETER["scale_factor",0.9999],
> PARAMETER["false_easting",0],
> PARAMETER["false_northing",0],
> UNIT["Meter",1]]
> This is not quite right.
Mhh, not sure about my statement. Anyway, the map which I have to import
looks like this:
PROJCS["S-JTSK_Krovak",GEOGCS["GCS_S_JTSK",DATUM["D_S_JTSK",SPHEROID["Bessel_1841",6377397.155,299.1528128]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Krovak"],PARAMETER["False_Easting",0.0],PARAMETER["False_Northing",0.0],PARAMETER["Pseudo_Standard_Parallel_1",78.5],PARAMETER["Scale_Factor",0.9999],PARAMETER["Azimuth",30.28813975277778],PARAMETER["Longitude_Of_Center",24.83333333333333],PARAMETER["Latitude_Of_Center",49.5],PARAMETER["X_Scale",1.0],PARAMETER["Y_Scale",1.0],PARAMETER["XY_Plane_Rotation",0.0],UNIT["Meter",1.0]]
And:
g.proj wkt=Area_topolcianky.prj
g.proj -w
PROJCS["Krovak",
GEOGCS["bessel",
DATUM["unknown",
UNIT["Meter",1]]
Doesn't seem to correspond (see pseudo_standard_parallel_1, scale_factor etc).
Markus
