[GRASS-dev] [grass-code I][390] v.parallel: problems with inside corners
grass-codei at wald.intevation.org grass-codei at wald.intevation.org
Fri May 4 01:53:59 EDT 2007
code I item #390, was opened at 2007-05-04 17:53
Status: Open
Priority: 3
Submitted By: Hamish Bowman (hamish)
Assigned to: Nobody (None)
Summary: v.parallel: problems with inside corners
Issue type: library bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: vector
Operating system: all
Operating system version:
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
There is a problem with v.segment side-offset parallel line generation for inside corners. It is in Vect_line_parallel(), so v.parallel, v.buffer, et al. are also affected. See it by doing the "-500" side-offset example in the v.segment help page and changing -500 to +500. Or do "v.parallel dist=500" using the railroads vector map.
Hamish
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=390&group_id=21
