[GRASS-dev] font path question for Linux and Windows
Paul Kelly paul-grass at stjohnspoint.co.uk
Mon May 7 08:02:56 EDT 2007
On Fri, 4 May 2007, Paul Kelly wrote:
> On Fri, 4 May 2007, Glynn Clements wrote:
>> William Kyngesburye wrote:
>>> It's already been discussed (r.in.wms problem) that /I is a GNU
>>> extension to sed.  OSX, at least, is BSD.  Don't know what to say
>>> otherwise...
>> An alternative is to change -iname to -name, and include both upper-
>> and lower-case versions of the extension in exts.
> OK, that works (see patch below). The font names are a bit cryptic though, as
> they all seem to be constrained to the 8 character limit, but I suppose that
> isn't so important.
I've committed this patch to CVS (with a slight change to include the new
extensions that Michael added).
> Index: mkftcap
> RCS file: /home/grass/grassrepository/grass6/tools/mkftcap/mkftcap,v
> retrieving revision 1.6
> diff -u -r1.6 mkftcap
> --- mkftcap     3 May 2007 04:25:17 -0000       1.6
> +++ mkftcap     4 May 2007 10:26:51 -0000
> @@ -1,6 +1,6 @@
> #!/bin/sh
> -exts='ttf pfa pfb'
> +exts='ttf TTF pfa PFA pfb PFB'
>     for dir in /usr/lib/X11/fonts /usr/share/X11/fonts /usr/share/fonts \
> @@ -10,7 +10,7 @@
>     do
>         if [ -d "$dir" ] ; then
>             for ext in $exts ; do
> -                find "$dir" -type f -iname '*.'"$ext" -print \
> +                find "$dir" -type f -name '*.'"$ext" -print \
>                     | sed 's!^\(.*\)/\(.*\)$!\2:\1/\2:utf-8:!' \
>                     | sed 's/\.'"$ext"':/:/'
>             done
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
