[GRASS-dev] S-JTSK strikes back
Paul Kelly
paul-grass at stjohnspoint.co.uk
Fri May 4 07:57:02 EDT 2007
Hello Martin
On Fri, 4 May 2007, Martin Landa wrote:
>> information (the alpha value) is lost when converting from GRASS format
>> back to WKT. Is this important? I don't know anyway how important alpha
>> and pseudo standard parallel are. Are they important for proj=krovak or
>> does it just ignore it? It seems alpha corresonds to Azimuth in the WKT and
>> OSRImportFromProj4() isn't converting it properly, but I really don't know
>> how important it is for proj=krovak so wouldn't like to get too deeply
>> involved there... Likewise for Pseudo_Standard_Parallel_1 and
>> OSRExportToProj4().
> Latitude of pseudo standard parallel (78d30m) is hard-coded in
> PJ_krovak.c and alpha I guess is ignored.
OK thanks for clearing this up a bit. So it isn't a big problem then. Just
a bit messy.
> I see problem using g.proj epsg=2065 -p / -w :
> PRIMEM["ferro",-17.666666666668]
> PARAMETER["longitude_of_center",24.833333333332], <- not Ferro, but Greenwich
Yes this is the problem we came across before. It is currently the subject
of a pending bug report in OGR: http://trac.osgeo.org/gdal/ticket/367
Paul
> x
> pm : ferro
> lon_0 : 42.5 <- OK
> Martin
>> Paul
>> grass-dev mailing list
>> grass-dev at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grass-dev
> Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
