[GRASS-dev] S-JTSK strikes back
Martin Landa
landa.martin at gmail.com
Thu May 3 06:43:24 EDT 2007
I tried
2007/5/3, Markus Neteler <neteler at itc.it>:
> # S-JTSK (Ferro) / Krovak
> <2065> +proj=krovak +lat_0=49.5 +lon_0=42.5 +alpha=30.28813972222222 +k=0.9999 +x_0=0 +y_0=0 +ellps=bessel +pm=ferro +units=m +no_defs <>
> So I do:
> g.proj epsg=2065
g.proj epsg=2065 -c loc=s-jtsk datum=3
g.gisenv | grep LOC
LOCATION_NAME='s-jtsk';
g.proj -w
I got different values...
> g.proj -w
> DATUM["unknown",
> SPHEROID["Bessel_1841",6377397.155,299.1528128]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433]],
DATUM["Militar_Geographische_Institut",
PRIMEM["ferro",-17.666666666668],
PARAMETER["longitude_of_center",24.833333333332], <- This should
be 42.5 (because of Ferro)
I am wonder why g.proj -w gives different values...
g.proj -jf
+proj=krovak +lat_0=49.5 +lon_0=42.5 +k=0.9999 +x_0=0 +y_0=0 +pm=ferro
+no_defs +a=6377397.155 +rf=299.1528128
+towgs84=570.8,85.7,462.8,4.998,1.587,5.261,3.56 +to_meter=1
Martin
> This is not quite right. It should be
> http://lists.maptools.org/pipermail/proj/2003-February/000626.html
> something like this:
> PROJCS["S-JTSK (Ferro) / Krovak",
> GEOGCS["S-JTSK (Ferro)",
> DATUM["S_JTSK_Ferro",
> SPHEROID["Bessel 1841",6377397.155,299.1528128,
> AUTHORITY["EPSG","7004"]],
> AUTHORITY["EPSG","6818"]],
> PRIMEM["Ferro",-17.66666666666667,
> AUTHORITY["EPSG","8909"]],
> UNIT["degree",0.0174532925199433],
> AUTHORITY["EPSG","4818"]],
> PROJECTION["Krovak"],
> PARAMETER["latitude_of_center",49.5],
> PARAMETER["longitude_of_center",42.5],
> PARAMETER["azimuth",30.28813972222222],
> PARAMETER["pseudo_standard_parallel_1",78.5],
> PARAMETER["scale_factor",0.9999],
> PARAMETER["false_easting",0],
> PARAMETER["false_northing",0],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AUTHORITY["EPSG","2065"]]
> Is any name remapping still missing in
> lib/proj/convert.c
> Markus
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
