[GRASS-dev] S-JTSK strikes back
Paul Kelly
paul-grass at stjohnspoint.co.uk
Fri May 4 06:50:02 EDT 2007
On Thu, 3 May 2007, Markus Neteler wrote:
> Hi,
> for a project I need to define a S-JTSK location. I thought
> that we resolved this recently, but apparently not:
> # S-JTSK (Ferro) / Krovak
> <2065> +proj=krovak +lat_0=49.5 +lon_0=42.5 +alpha=30.28813972222222 +k=0.9999 +x_0=0 +y_0=0 +ellps=bessel +pm=ferro +units=m +no_defs <>
> So I do:
> g.proj epsg=2065
Hello Markus,
As far as I can remember it was only resolved in so far as we decided that
you couldn't create a Krovak location using EPSG codes and it needed to be
done manually using g.setproj? This was because of problems translating
WKT into a PROJ.4 description inside OGR, partly related to the fact that
"proj=krovak" is still kind of temporary and has various paramters
hard-coded in it and a good flexible translation will require to use the
new "proj=kocc" when it is eventually merged into PROJ.4. But if you think
there is more to it than this then I can look into it more.
Paul
> g.proj -w
> PROJCS["Krovak",
> GEOGCS["bessel",
> DATUM["unknown",
> SPHEROID["Bessel_1841",6377397.155,299.1528128]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433]],
> PROJECTION["Krovak"],
> PARAMETER["latitude_of_center",49.5],
> PARAMETER["longitude_of_center",24.83333333333333],
> PARAMETER["azimuth",0],
> PARAMETER["pseudo_standard_parallel_1",0],
> PARAMETER["scale_factor",0.9999],
> PARAMETER["false_easting",0],
> PARAMETER["false_northing",0],
> UNIT["Meter",1]]
> This is not quite right. It should be
> http://lists.maptools.org/pipermail/proj/2003-February/000626.html
> something like this:
> PROJCS["S-JTSK (Ferro) / Krovak",
> GEOGCS["S-JTSK (Ferro)",
> DATUM["S_JTSK_Ferro",
> SPHEROID["Bessel 1841",6377397.155,299.1528128,
> AUTHORITY["EPSG","7004"]],
> AUTHORITY["EPSG","6818"]],
> PRIMEM["Ferro",-17.66666666666667,
> AUTHORITY["EPSG","8909"]],
> UNIT["degree",0.0174532925199433],
> AUTHORITY["EPSG","4818"]],
> PARAMETER["longitude_of_center",42.5],
> PARAMETER["azimuth",30.28813972222222],
> PARAMETER["pseudo_standard_parallel_1",78.5],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AUTHORITY["EPSG","2065"]]
> Is any name remapping still missing in
> lib/proj/convert.c
> Markus
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
