[GRASS-dev] ps.map: raster always under vector map?
Glynn Clements
glynn at gclements.plus.com
Sun May 6 11:03:27 EDT 2007
Markus Neteler wrote:
> > FWIW, what are the main advantages of ps.map over using the PS driver
> > and d.* commands?
> Certainly I tried this as well. If I recall correctly, the
> PS file size from PS driver/d.* was way bigger than the
> output of ps.map. In my case I was getting hundreds of MB.
> I can try again of course.
I'd suggest looking at which parts of the output are taking up all of
the space. If it's the raster, that suggests that the two attempts
were using different resolutions. If it's the vectors, different
render= options might help (for filled areas, the default render=g
setting will produce excessively large output and worse quality).
