[GRASS-dev] ps.map: raster always under vector map?
Markus Neteler
neteler at itc.it
Sun May 6 06:41:21 EDT 2007
On Sun, May 06, 2007 at 10:53:49AM +0100, Glynn Clements wrote:
> FWIW, what are the main advantages of ps.map over using the PS driver
> and d.* commands?
Certainly I tried this as well. If I recall correctly, the
PS file size from PS driver/d.* was way bigger than the
output of ps.map. In my case I was getting hundreds of MB.
I can try again of course.
Markus
