[GRASS-dev] iconv a required dependency for using Freetype?
    Glynn Clements
    glynn at gclements.plus.com
    Mon May  7 10:32:01 EDT 2007
Paul Kelly wrote:
> >>> FWIW, the robust way to check whether two paths are equivalent is to
> >>> stat() (or lstat()) both of them, and check whether the device and
> >>> inode numbers match.
> >> Interesting; here we are comparing the directory the fonts are stored in
> >> rather than the font files themselves but perhaps still of use?
> > Yes; in the case of COM_Font_get(), you would need to remove the last
> > part of the path and check whether the directory part refers to the
> > same device/inode as $GISBASE/fonts.
> OK well it doesn't work on Windows anyway. The device number corresponds
> to the drive letter but it appears the inode number is always 0. So I
> suppose we can just keep the string comparison of the directory names. Or
> remove the option of specifying the full path to a GRASS stroke font - I
> generally feel unhappy with the idea of removing functionality but maybe
> it is the best option here?
I think so.
Allowing a full path is exposing an implementation detail, it isn't
sufficient for files containing multiple faces, and it may cause
problems with future development.
I would rather just have fonts selected by an abstract identifier.
> >>> Also, I'd guess that using a colon as the field separator is likely to
> >>> be problematic on Windows.
> >> Yes, that was it. If I use a semi-colon instead all works great - maybe we
> >> could change mkftcap to generate a file with semi-colon separators? And
> >> change parse_freetypecap() to handle both for backwards compatibility? Is
> >> the last character on a line in freetypecap always a separator character?
> >> If so that would be a quick way to check. Or could scan the first line and
> >> whichever appeared first between : and ; use that as the separator?
> > If it's going to be changed, one option is to use a vertical bar
> > (which isn't a legal filename character on Windows), and make the face
> > index a separate column.
> I can't see an easy way though of keeping old freetypecap files compatible
> with the current reading code that way though - just recognising an
> alternative separator character doesn't seem to be too disruptive (apart
> from adding extra code and requiring it to be kept there for ever.)
I don't think that maintaining compatibility is all that important.
The original freetypecap format is something which Huidae made up on
the spot. It's already lost the colour/size fields, and the encoding
field isn't actually used.
> > That would eliminate the possibility of using a non-zero index when
> > specifying a font by a pathname, but that's problematic for other
> Yes but that's quite neat and an easy and simple way of specifying a
> non-zero index if you need to, I thought.
> > reasons (e.g. gisprompt = "old_file,..." should probably check for
> > file existence, which would rule out the option of using something
> > which is "almost" a filename).
> Yes if the font was being specified through a module like d.font - I
> suppose an extra parameter could be added to specify the index. But when
> the font is just being read from an environment variable then it's more
> complicated and anyway the parser isn't going to be involved here so as
> far as I can see the check for file existence needs to be done manually
> anyway as it currently is.
Yes, but we should be able to use a generic file existence check,
without having to worry about hacks. When I was implementing the face
index hack, it took several iterations to get it right (either
forgetting to strip the index for the check, or inadvertantly using
the stripped version when the index was needed). My suspicion is that
the index hack will bite people continuously so long as it's around.
> > AFAIK, the trailing separator is an artifact of the time that style
> > information (colour, size) was included in the freetypecap file.
> > BTW, the encoding field isn't used either (d.font.freetype and
> > d.text.freetype used it, but the driver doesn't).
> > Note that d.font has code which parses the freetypecap file in order
> > to generate the option list for font=, and to implement the -l switch,
> > so that will need to be updated if the format changes.
> > d.font.freetype and d.text.freetype have similar code, but they no
> > longer need to be maintained; they have been replaced by scripts which
> > call d.font and d.text (which is actually d.text.new) respectively.
> OK. Well here is my current proposal, which can be easily added to both
> d.font and libdriver: dynamically generate the format conversion string
> (containing either a : or ; as separator) based on the relative position
> of : and ; characters in the first line of the file that contains either
> of them.
> The code looks like below; it is complicated but I can't see how to make
> it simpler without losing backwards compatibility. I'm not quite happy
> enough with it to commit it yet. It can be easily included in both d.font
> and libdriver as-is, though.
Here's my proposal: don't bother maintaining compatibility with the
current freetypecap format or the ability to select fonts by absolute
path. Both of those were made up on the spot without any real
consideration.
