[GRASS-dev] iconv a required dependency for using Freetype?
Paul Kelly paul-grass at stjohnspoint.co.uk
Mon May 7 11:02:22 EDT 2007
On Mon, 7 May 2007, Glynn Clements wrote:
> Here's my proposal: don't bother maintaining compatibility with the
> current freetypecap format or the ability to select fonts by absolute
> path. Both of those were made up on the spot without any real
> consideration.
So what about having a totally new file, let's call it fontcap - different
name to make it clear there is no backwards compatiblity. It could include
the stroke fonts as well as freetype-compatible fonts, with a field to
indicate whether the font is stroke or freetype, also absolute filename,
index within the file, perhaps a field for a descriptive/long name too.
I wonder if something like this is what Michael had in mind when we
started this whole discussion - a simple list of all the avaiable fonts
that could be offered to the user to choose from through the GUI?
It would be generated automatically on compilation/installation and then
the user could further edit it to add to / strip it down if required.
Wolf said he was interested in writing something to automatically extract
information from font files on the system - maybe what he comes up with
can be used to generate this fontcap file. And then once we're finished
GRASS_FONT can only contain a font id string from this file - nothing else
is accepted. Does that sound like it might be workable?
