[GRASS-dev] [grass-code I][393] projected raster map looses reclass data
grass-codei at wald.intevation.org grass-codei at wald.intevation.org
Mon May 7 11:54:17 EDT 2007
code I item #393, was opened at 07/05/2007 15:54
Status: Open
Priority: 3
Submitted By: Alessandro Frigeri (alf)
Assigned to: Nobody (None)
Summary: projected raster map looses reclass data
Issue type: library bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: raster
Operating system: Linux
Operating system version: Debian amd64/unstable
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
Reprojecting (r.proj) a reclassed map results in a map without the original reclass informations.
The reclass file ($grassdb/$location/$mapset/cats/mymap) shows up:
--BEGIN
# 7 categories
0.00 0.00 0.00 0.00
--END
so it seems that the '7 categories' list is just not written to the file.
Regards,
Alessandro
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=393&group_id=21
