[GRASS-dev] GRASS 6.2.2 release candidate preparation
Markus Neteler neteler at itc.it
Tue May 8 06:08:15 EDT 2007
On Tue, May 08, 2007 at 09:54:31PM +1200, Hamish wrote:
> Markus Neteler wrote:
> > * NVIZ: volume problem (test with slovakia3d dataset) bug #4725 (Bob)
> >   -> I have backported this fix, it seems to cure the problem
> not 100% cured, see end of the bug report:
>   https://intevation.de/rt/webrt?display=History&serial_num=4725
> G622> nviz vol=vox50
> #loads ok  (see bug report for generating vox50)
> # view height -> 75.0
> # Visualize -> Volumes
> # Isosurface [Add]
> Segmentation fault
> Try again, then it works ok.
Confirmed.
> Same thing if started with "nviz -q" then load [New] Raster Volume.
> First time you add a new isosurface it segfaults, if you restart nviz
> then it works. Smells like a little uninit'd memory error remains.
> Previously, AFAIK, it didn't segfault if you started with "nviz -q".
> Apparently the fix makes the command line way better, but the manual
> add way worse. ??
Well, I dunno...
I just feel that we should not delay RC1 forever.
Markus
