[GRASS-dev] iconv a required dependency for using Freetype?
    Glynn Clements
    glynn at gclements.plus.com
    Tue May  8 06:24:12 EDT 2007
Michael Barton wrote:
> > note the last act of tools/mkftcap is "| sort | uniq", so some of this
> > work is already done for you. Where do the duplicates come from then?
> Same fonts in different directories. uniq sees them as different because
> they have different paths, in spite of being the same font.
There's no way that mkftcap can determine that they are actually the
same font.
What it should do is to add a suffix to duplicate names, so that you
can select either one (at present, only the first one with any given
name can be selected). Realistically, that would require mkftcap to be
written in a real language.
