[GRASS-dev] cause for bad colors in output from png driver
Hamish
hamish_nospam at yahoo.com
Wed May 9 21:11:47 EDT 2007
Glynn Clements wrote:
> The framebuffer is always stored as B,G,R,A (the format used by 32-bpp
> BMP files).
(answers my earlier r.what.color question)
> This corresponds to 0xAARRGGBB on a little-endian system and
> 0xBBGGRRAA on a big-endian system (e.g. Mac).
dumb question: are Intel Macs now little endian?
> Externally (DRV_color, DRV_lookup_color), the alpha value is always
> zero (0 = opaque, 255 = transparent),
in gis.h I used:
typedef struct
unsigned char r, g, b, a; /* red, green, blue, and alpha */
} RGBA_Color ;
typedef RGBA_Color RGB_Color;
/* RGBA_Color alpha presets */
#define RGBA_COLOR_OPAQUE 255
#define RGBA_COLOR_TRANSPARENT 0
#define RGBA_COLOR_NONE 0
Are the above alpha OPAQUE and TRANSPARENT values backwards? I had
pictured alpha as opacity, with OPAQUE being 100% and TRANSPARENT as 0%.
COLOR_NONE is used to indicate that the RGB array hasn't been filled.
(d.vect color=none)
Hamish
