[GRASS-dev] Re: not quite there on fonts
Paul Kelly
paul-grass at stjohnspoint.co.uk
Fri May 11 13:33:00 EDT 2007
On Fri, 11 May 2007, Michael Barton wrote:
> I just updated a Mac in the lab. d.font l returns nothing, which makes the
> font list empty in the GUI. I tried manually running g.mkfontcap with a
Does it work OK if you start a monitor first (d.mon x0)? I think, because
of the way it now uses R_* functions it depends in some way on having some
valid display output working. From the commandline on Linux I noticed too
it outputs nothing, but when I set GRASS_RENDER_IMMEDIATE=TRUE first then
it outputs the list. On Windows the list showed up fine. So I was assuming
that gis.m must have set GRASS_RENDER_IMMEDIATE=TRUE and thus everything
was OK. Maybe there's something else on Windows that causes
GRASS_RENDER_IMMEDIATE=TRUE to be set? Or maybe I'm barking up the wrong
tree?
> couple of different option. g.mkfontcap is indeed doing its thing, putting
> stuff into fontcap and freetypecap. But d.font is not reading it.
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics and Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
