[GRASS-dev] Re: not quite there on fonts
Michael Barton
michael.barton at asu.edu
Fri May 11 13:44:27 EDT 2007
Well, this is a clue indeed.
If I open an xmon (d.mon x0), d.font -l makes a nice list of fonts and these
even show up in the gui.
If I close the xmon, d.font -l shows nothing (and the nice font list goes
away).
GRASS_RENDER_IMMEDIATE is set to TRUE in the GUI, but that doesn't seem to
make any difference.
Michael
On 5/11/07 10:33 AM, "Paul Kelly" <paul-grass at stjohnspoint.co.uk> wrote:
> On Fri, 11 May 2007, Michael Barton wrote:
>> I just updated a Mac in the lab. d.font l returns nothing, which makes the
>> font list empty in the GUI. I tried manually running g.mkfontcap with a
> Does it work OK if you start a monitor first (d.mon x0)? I think, because
> of the way it now uses R_* functions it depends in some way on having some
> valid display output working. From the commandline on Linux I noticed too
> it outputs nothing, but when I set GRASS_RENDER_IMMEDIATE=TRUE first then
> it outputs the list. On Windows the list showed up fine. So I was assuming
> that gis.m must have set GRASS_RENDER_IMMEDIATE=TRUE and thus everything
> was OK. Maybe there's something else on Windows that causes
> GRASS_RENDER_IMMEDIATE=TRUE to be set? Or maybe I'm barking up the wrong
> tree?
>> couple of different option. g.mkfontcap is indeed doing its thing, putting
>> stuff into fontcap and freetypecap. But d.font is not reading it.
>> Michael
>> __________________________________________
>> Michael Barton, Professor of Anthropology
>> School of Human Evolution & Social Change
>> Center for Social Dynamics and Complexity
>> Arizona State University
>> phone: 480-965-6213
>> fax: 480-965-7671
>> www: http://www.public.asu.edu/~cmbarton
phone: 480-965-6213
fax: 480-965-7671
