Hi, I found two annoying bugs in d.rast.edit (binary version). As you can see from http://geni.ath.cx/grass/d.rast.edit.png , R_panel_save/store don't seem to work and R_set_window, which calls XSetClipRectangles, is effective even after the menu disappears. The relevant code is in lib/display/popup.c. Does anyone have any idea? Huidae Cho
