[GRASS-dev] Re: not quite there on fonts
Glynn Clements
glynn at gclements.plus.com
Sun May 13 03:14:22 EDT 2007
Michael Barton wrote:
> >> Given what you say above, can I set all of these for the GUI session and not
> >> worry about their impact on how grass functions from the command line during
> >> that session?
> >> set env(GRASS_BACKGROUNDCOLOR) "ffffff"
> Playing around with this variable in wxPython, it doesn't seem to do much of
> anything--probably because we need to set the background color of the
> composited map (i.e., all layers) with g.pnmcomp.
GRASS_BACKGROUNDCOLOR is irrelevant if $GRASS_TRANSPARENT == TRUE.
> I *can* change *that*
> color and it does give a new background. But I was getting odd results from
> the maps when I changed transparancy. I wonder if it's possible for
> g.pnmcomp to have a transparent background?
If you specify outmask=, g.pnmcomp should write out a PGM mask file.
The main problem is that (AFAICT) you can't use it in Tcl/Tk; the only
way to get a masked "photo" image is from a GIF file.
