[GRASS-dev] Re: not quite there on fonts
Fri May 11 16:26:32 EDT 2007
Michael Barton wrote:
> If I open an xmon (d.mon x0), d.font -l makes a nice list of fonts and these
> even show up in the gui.
> If I close the xmon, d.font -l shows nothing (and the nice font list goes
> away).
> GRASS_RENDER_IMMEDIATE is set to TRUE in the GUI, but that doesn't seem to
> make any difference.
If the behaviour of "d.font -l" within the GUI varies depending upon
whether or not an X monitor is running, then
env(GRASS_RENDER_IMMEDIATE) isn't actually set to TRUE at the point
that "d.font -l" is executed.
