[GRASS-dev] new tests on wxgui
Paul Kelly paul-grass at stjohnspoint.co.uk
Sun May 13 09:21:47 EDT 2007
On Mon, 14 May 2007, Hamish wrote:
> Another wish for module GUI tabs: (at least for tcl/tk)
> Allow spaces in the tab names. Right now we have to use_underscores.
> Proably just some quoting somewhere. Better control over tab order would
> be nice too. Right now (tcl) the first flag given determines the first
> tab name, which is annoying if you want all flags in secondary tab. Also
> Options is hardcoded as the default tab, which makes it hard to work with
> if you don't want that tab to come first.
> see wish #238
>  http://wald.intevation.org/tracker/index.php?func=detail&aid=238
IIRC from partly digging into this a while ago, the place to look for
changing it is G_tcltk() in lib/gis/parser.c. ISTR also the the Python GUI
uses G_usage_xml() for generating option dialogs (also in parser.c), so
maybe the issue doesn't apply there?
Paul
