[GRASS-dev] standard input options messed up in current CVS
Markus Neteler
neteler at itc.it
Mon May 14 11:24:23 EDT 2007
On Mon, May 14, 2007 at 04:18:05PM +0200, Benjamin Ducke wrote:
> hi all,
> I just did a fresh rebuild from CVS an hour ago and noticed that
> standard option declarations (G_OPT_V_FIELD, G_OPT_R_OUTPUT,
> G_OPT_V_MAP) are no longer working. Options declared this way get
> totally messed up. Have a look at v.out.ogr for an an example.
I bet that you need to run
make distclean
before recompiling.
Markus
