[GRASS-dev] standard input options messed up in current CVS
Benjamin Ducke benjamin.ducke at ufg.uni-kiel.de
Mon May 14 12:40:09 EDT 2007
Sorry, no luck. Did a distclean and recompiled. Same problem.
Do you have it, too?
Ben
Markus Neteler wrote:
> On Mon, May 14, 2007 at 04:18:05PM +0200, Benjamin Ducke wrote:
>> hi all,
>> I just did a fresh rebuild from CVS an hour ago and noticed that
>> standard option declarations (G_OPT_V_FIELD, G_OPT_R_OUTPUT,
>> G_OPT_V_MAP) are no longer working. Options declared this way get
>> totally messed up. Have a look at v.out.ogr for an an example.
> I bet that you need to run
>  make distclean
> before recompiling.
> Markus
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
