[GRASS-dev] standard input options messed up in current CVS
Mon May 14 23:38:47 EDT 2007
Benjamin wrote:
> >> I just did a fresh rebuild from CVS an hour ago and noticed that
> >> standard option declarations (G_OPT_V_FIELD, G_OPT_R_OUTPUT,
> >> G_OPT_V_MAP) are no longer working. Options declared this way get
> >> totally messed up. Have a look at v.out.ogr for an an example.
Markus:
> > I bet that you need to run
> >  make distclean
> > before recompiling.
Benjamin:
> Sorry, no luck. Did a distclean and recompiled. Same problem.
> Do you have it, too?
Looks ok for me using yesterday's CVS. What do the broken bits look
like? Are they taking descriptions etc from another std option?
I did add a new standard option the other day (for fs=), but added it to
the end of the STD_OPT list. I thought doing that would only cause
distclean problems if I had added it to the middle of the list, i.e.
reordering the index.
Hamish
