[GRASS-dev] Re: [bug #5185] shared library problem solaris
Mon May 14 19:06:36 EDT 2007
Paul Kelly wrote:
> >> Sorry to say, but it does not yet work; I do have a suspicion, that the
> >> test in aclocal.m4 on line 1137 is the reason: `uname -s`-`uname -r`
> >> (aclocal.m4 line 446) gives 'SunOS-5.10' on the system I'm using, and
> >> the results do indicate, that contrary to what planned, the system is
> >> treated as on of 5.0 to 5.6.
> >> Harri K.
> > ... new ideas are welcome again...
> Looks like it is treating 5.1.* and 5.10* the same - adding an extra dot
> into the matching expression should fix it I would hope:
This might be a good time to think about eliminating the use of
"uname" and using $host like it should.
