[GRASS-dev] [grass-code I][397] It's impossible to assign a color
	to vector layer in GIS Manager
    Glynn Clements
    glynn at gclements.plus.com
    Mon May 14 19:15:44 EDT 2007
grass-codei at wald.intevation.org wrote:
> code I item #397, was opened at 14/05/2007 23:18
> Status: Open
> Priority: 3
> Submitted By: Lorenzo Moretti (lorenzom)
> Assigned to: Nobody (None)
> Summary: It's impossible to assign a color to vector layer in GIS Manager
> Issue type: module bug
> Issue status: None
> GRASS version: CVS HEAD
> GRASS component: vector
> Operating system: MacOS X
> Operating system version: 10.4
> GRASS CVS checkout date, if applies (YYMMDD): 070505
> Initial Comment:
> In GRASS cvs 070505 there is a bug NOT present in GRASS 6.2.1.
> In GRASS 6.2.1 like any GRASS version you can assign any color to a vector line or vector area.
> Now in the last cvs when I press the view button I see all layers but there is an error in GIS.m Ouput if I select a color not black:
> Color: can't set color 858993408
> Color: can't set color 858993408 (or other numbers for another color)
> All vector layers are black !!!
> I have this error in GRASS inside X11 and GRASS inside OS X (without X11)
> Why ?
> This is a new bug
It was fixed on 2007/05/09.
