[GRASS-dev] [grass-code I][397] It's impossible to assign a color
	to vector layer in GIS Manager
    grass-codei at wald.intevation.org
    Mon May 14 17:18:46 EDT 2007
code I item #397, was opened at 14/05/2007 23:18
Status: Open
Priority: 3
Submitted By: Lorenzo Moretti (lorenzom)
Assigned to: Nobody (None)
Summary: It's impossible to assign a color to vector layer in GIS Manager
Issue type: module bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: vector
Operating system: MacOS X
Operating system version: 10.4
GRASS CVS checkout date, if applies (YYMMDD): 070505
Initial Comment:
In GRASS cvs 070505 there is a bug NOT present in GRASS 6.2.1.
In GRASS 6.2.1 like any GRASS version you can assign any color to a vector line or vector area.
Now in the last cvs when I press the view button I see all layers but there is an error in GIS.m Ouput if I select a color not black:
Color: can't set color 858993408
Color: can't set color 858993408 (or other numbers for another color)
All vector layers are black !!!
I have this error in GRASS inside X11 and GRASS inside OS X (without X11)
Why ?
This is a new bug
Lorenzo
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=397&group_id=21
