[GRASS-dev] new tests on wxgui
Hamish
hamish_nospam at yahoo.com
Tue May 15 03:50:16 EDT 2007
Michael Barton wrote:
> > I didn't find an option to say that I don't want vector areas to be
> > filled. I did found where to change the colors, but not the "no
> > fill" option.
> We need a transparent (none) option here--like in the dialog for
> d.barscale.
Sending it "d.vect fcolor=none" should work.
the only difference with d.barscale is that the label for d.barscale's
color option explicitly states that "none" works.
The Tcl GUI for ->gisprompt=GISPROMPT_COLOR doesn't have a "none" button,
it probably should.
"d.rast.num grid_color=none" is slightly different, there we do:
opt2->options = D_COLOR_LIST ",none";
opt2->key_desc = "color";
opt2->description = _("Color for drawing grid, or \"none\"");
(that gives you a pulldown list and won't take RRR:GGG:BBB)
Hamish
