[GRASS-dev] new tests on wxgui
Moritz Lennert
mlennert at club.worldonline.be
Tue May 15 08:07:50 EDT 2007
On 15/05/07 13:30, Carlos "Guâno" Grohmann wrote:
>> > The thing about you have to close the command window to refresh the
>> > display goes for other commands, also. For instance, if I use
>> > g.region, and change the region settings, I can't refresh the map
>> > until I hit "Cancel" in g.region window. I should be able to change
>> > the settings, refresh the display to see if that is what I want and
>> > then hit "close" to close the window (instead of "cancel" which is
>> > counter-intuitive). In this particular case (g.region) tha "Aplly" or
>> > "Run" button is usefull, it would aplly the canges, we would see if
>> > it's OK, and then the OK would close the window (and apply the changes
>> > again, but it wouldn't make any harm).
>> Remember, the computational region (set with g.region) will not affect
>> the
>> display region or vice versa, unless you explicitly tell GRASS to do so.
> I know that, but I want to _see_ if my computational region is really
> the size I want.
How about a an option allowing you to display the computational region
as a box in the map display (cf QGIS) ?
Moritz
