[GRASS-dev] Re: [grass-addons] r659 -
trunk/grassaddons/gui/gui_modules
Michael Barton
michael.barton at asu.edu
Wed May 16 11:27:59 EDT 2007
Martin,
Are you thinking that we should change all calls to GRASS commands to use
the new cmd module?
Michael
On 5/16/07 2:09 AM, "landa at grass.itc.it" <landa at grass.itc.it> wrote:
> Author: landa
> Date: 2007-05-16 11:09:42 +0200 (Wed, 16 May 2007)
> New Revision: 659
> Modified:
> trunk/grassaddons/gui/gui_modules/mapdisp.py
> Log:
> fixing 'Zoom to saved region'
> Modified: trunk/grassaddons/gui/gui_modules/mapdisp.py
> --- trunk/grassaddons/gui/gui_modules/mapdisp.py 2007-05-15 23:55:41 UTC (rev
> 658)
> +++ trunk/grassaddons/gui/gui_modules/mapdisp.py 2007-05-16 09:09:42 UTC (rev
> 659)
> @@ -851,21 +851,21 @@
> zoomreg = {}
> dlg = SavedRegion(self, wx.ID_ANY, "Zoom to saved region extents",
> - pos=wx.DefaultPosition, size=wx.DefaultSize,
> - style=wx.DEFAULT_DIALOG_STYLE,
> - loadsave='load')
> + pos=wx.DefaultPosition, size=wx.DefaultSize,
> + style=wx.DEFAULT_DIALOG_STYLE,
> + loadsave='load')
> if dlg.ShowModal() == wx.ID_CANCEL:
> dlg.Destroy()
> return
> wind = dlg.wind
> - cmd = "g.region -ugp region=%s" % wind
> + cmdString = "g.region -ugp region=%s" % wind
> - try:
> - p = Popen(cmd, shell=True, stdin=PIPE, stdout=PIPE, stderr=PIPE,
> close_fds=True)
> + p = cmd.Command (cmdString)
> - output = p.stdout.read().split('\n')
> + if p.returncode == 0:
> + output = p.module_stdout.read().split('\n')
> for line in output:
> line = line.strip()
> if '=' in line: key,val = line.split('=')
> @@ -877,14 +877,6 @@
> self.ZoomHistory(self.Map.region['n'],self.Map.region['s'],self.Map.region['e'
> ],self.Map.region['w'])
> self.UpdateMap()
> - if p.stdout < 0:
> - print >> sys.stderr, "Child was terminated by signal",
> p.stdout
> - elif p.stdout > 0:
> - #print >> sys.stderr, p.stdout
> - pass
> - except OSError, e:
> - print >> sys.stderr, "Execution failed:", e
> dlg.Destroy()
> def SaveDisplayRegion(self, event):
> grass-commit-addons mailing list
> grass-commit-addons at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-commit-addons
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
